Advice On Subpanel/water Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2010, 12:41 PM   #1
advice on Subpanel/water heater
Finishing on an added on kitchen and thinking of getting a small water heater to supply it. I want to place it near the kitchen but also want to install a subpanel to supply the water heater and a home theater room.
Questions are:
1. Is it possible to have too many large breakers in a main panel?
I will have
(2) 60 amp DP for AC
(1) 30 amp DP for existing water heater
(1) 50 amp DP for range
(1) 60 amp DP for proposed subpanel
I have this in a 20 space 200 amp murray panel.
2. Will the kitchen water heater mess with the home theater equipment? Since it would all be on the same panel. Not sure what the term would be.
3. Would it violate code to have a water heater and subpanel in close proximity?
thanks for your time.
rustic is offline   Reply With Quote
Old 04-21-2010, 03:12 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
#1-No
#2-No
#3-As long as the requirment for acessing the panel is met, not a problem.
See Scuba Dave's nec thread above for a pic of the space needed for a panel or subpanel.
Old 04-21-2010, 03:14 PM   #3
awesome
Old 04-21-2010, 04:12 PM   #4
Rewards Points: 1,216
Sounds like an awful lot of amperage for 2 A/C units.
COLDIRON is offline   Reply With Quote
Old 04-21-2010, 04:32 PM   #5
well its 20k heater that takes that juice, but it has a heat pump so it wont be that bad i guess.
its 2 breakers not 2 AC's
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
advice in removing plastic drain valve from water heater darsunt Plumbing 1 06-15-2009 04:30 PM
Water heater flue advice... skipjack Plumbing 2 08-18-2008 05:25 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
