Advice On Potential Generator Hook Up - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 07:40 PM   #1
Do it right.
advice on potential generator hook up
I live in a "duplex" (more like basement converted to apt.) and I have 2 service panels, I just replaced both boxes so I could use the mechanical interlocks I bought from Square D, my question is, is this a logical way to divide generator power to both boxes....
Run wire in conduit from an outside location to a sub panel that will distribute power to (2) double pole 30A breakers that will run to their respective box and connect to the double poles occupying slots 2 and 4 of each box.
opinions appreciated
SubSailor is offline   Reply With Quote
Old 11-08-2010, 09:10 PM   #2
Electrical Contractor
kbsparky's Avatar
Yup. AS long as those mechanical interlocking mechanisms are properly installed.
-KB
Old 11-08-2010, 09:29 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Oui., I have done that before and make sure you mark down the circuits as well due you will move at least two circuits around.
Merci.
Marc
Old 11-09-2010, 06:15 AM   #4
Do it right.
Merci.
Marc
My box was never labeled to begin with, figuring out the circuits is on my list of things to do
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 11:02 AM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 08:40 AM
voltage potential around in-ground pool logi98 Electrical 20 07-05-2009 08:08 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
