Advice Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2009, 05:16 AM   #1
Unhappy
advice needed
Hi There
Just a random question. Your help would be greatly appreciated.
I am in the process of renting a business unit and the estate agent responsible for the unit brought this dilemma to my attention.
Basically, next to the elcectric meter there is a white pipe which has been cut right through. eon and scottish power have advised that they cannot understand why the pipe has been cut as they do not use a proceedure such as this to suspend services. Is this a costly job to repair and how long would it take repair. Would it mean any underground work ?
Many Thanks
Ignomony_46
ignomony_46 is offline   Reply With Quote
Old 06-28-2009, 05:52 AM   #2
Whatamess
Is there wires in the pipe? Is it just empty? Picture would help.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 06-28-2009, 09:22 AM   #3
advice needed
Hi Thanks for your response. The pipe is empty, no wires running through it
Old 06-28-2009, 09:47 AM   #4
WFO
Typically if used for electric considerations, the pipe would be gray. White PVC indicates water or, more likely, waste. Of course this would depend on who did the installation.
Any idea where it goes? As noted above, a pic and/or more detail will help.
WFO is offline   Reply With Quote
Old 06-28-2009, 09:50 AM   #5
thanks
Thank you for your 2nd reply. I am going to take a picture and post it for you to see.
Thanks Again
Old 06-28-2009, 10:18 AM   #6
Rewards Points: 204
In the US the landlord would be responsible to repair any electrical issues. It's a liability thing and makes sense too.
Old 06-28-2009, 10:21 AM   #7
http://www.google.com/search?hl=en&s...nominy&spell=1
Advice needed. Complete Furnace & duct replacement - asbestos ductwrap (crawl space) vestaviascott HVAC 11 03-10-2009 05:40 PM
Forced air and radiant system advice needed jasoncave HVAC 1 01-06-2009 08:46 PM
Advice needed for Basement Wall nh10ring Building & Construction 5 02-08-2008 06:45 PM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 11:17 AM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 07:03 PM
