Advice Need!!100 Amp From Panel To Disconnect - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2007, 10:08 PM   #1
advice Need!!100 amp from panel to disconnect
I need some advice on an electrical issue as soon as possible.
I am working on a project and normally I have my electrician do my projects but he is unable to help me.
I need to take 100 amp breaker from the main panel(200amp) to a disconnect switch which is a 100 amp 3-phase.
I need to know what wire size i need and how to wire from the panel to the disconnect.
Thank you for any help!!!
rmkuenkel is offline   Reply With Quote
Old 06-01-2007, 12:09 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Your question is really beyond what would be advisable in a diy format. I would only recommend advice to a diy if the main panel is 208Y120 three phase. What do you have?
Stubbie
Old 06-01-2007, 05:44 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
IMO ANY 3-phase is out of the scope of DIY work. Besides, this is NOT DIY work, this is commercial. It is highly possible that you cannot even do the work legally. Does your liability insurance and workman's comp cover electrical work? I doubt it.
Find another electrician to do the work!
Speedy Petey is online now   Reply With Quote
Old 06-02-2007, 11:48 AM   #4
Rewards Points: 160
I agree with the others about the 3 phase to a point. It is no more dangerous than single phase. Also, everything is pretty much the same as far as installation.
1) Use # 3 copper wire for the three hots (phases) and the neutral.
2) Use # 8 " for the ground. Must be green for the complete length.
4) 5 wires total.
Now, how could anyone tell you how to "wire this "
You haven't provided any information that would enable someone to help you in this format.
If your electrician cannot help you. Go find another one.
Old 06-02-2007, 12:50 PM   #5
It is actually 50% more dangerous to the untrained person. There is one more big hot wire that can bite you.
Old 06-03-2007, 01:17 PM   #6
Rewards Points: 160
I guess you have a point
Old 07-06-2008, 05:39 AM   #7
3 phase disconnect ?
Hello, My name Is Jon Brewer and I am basically doing the same thing I have a 200 amp service running out to my shop and I am installing a Rotary Phase Converter.(To create my 3rd leg) The instructions tell me exactly what size wire and breaker to use.however, the wire and breaker size is determined by the amp draw of the unit or machine that you are installing. If you would like you can email me and we can share a bit of info since I have the code specs. I need to know where you got the disconnect so I can add one to my project. My email is apm08@netzero.net and I will be glad to give you the info.
Thanks, Jon.
apmjbrewer is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 05:55 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
