Advice For My New Toys! - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 01:17 PM   #1
Advice for my new toys!
I just purchased a new CNC table and compressor and I could use some help with the wiring. I was an apprentice for a few years so Im not completely numb on this subject. I should mention an electrician came and quoted me $800 to do this, so thats why Im here. 80 gallon compressor= 30 amps and the plug on the new plasma cutter is a 50 amp 220. The electricain said he was going to pull 4 #8 wires "45ft" into a deep J box with a 220 outlet for the plasma cutter and then run a whip over to the compressor. My question is, will #8 wire be ok for the#50 amp plasma outlet, or should I go with #6? Will this all fit into 3/4 conduit including a ground wire for each as well?What size should the grounds be? I was planning on installing one 60 amp and one 30 amp disconnect switch next to the machines since the breaker box is at the other side of the building. Could use some advice here, I'm not sure if what this guy was saying will be enough for what I'm doing? Thanks for the help
frodin1 is offline   Reply With Quote
Old 06-05-2012, 03:27 PM   #2
Could somone tell me how many #8 wires are permited in 3/4" EMT at 50 ft? I think it's only four but not sure?
Old 06-05-2012, 03:30 PM   #3
Post links to the spec's for your loads.
Old 06-05-2012, 03:36 PM   #4
I'll see if I can find something. Im going by what was on the labels.
Old 06-05-2012, 03:48 PM   #5
Link for the compressor. I do know the label says 230 volt on the pressure switch: http://www.tractorsupply.com/ingerso...0-gal--3496129
Link for the Plasma : http://www.lincolnelectric.com/asset...8-1/e11300.pdf
I don't really need a disconnect for the plasma I guess since its getting plugged in. But the compressor does get hardwired. My run is 50ft MAX its more like 45ft. from box to box. Im not sure if the 8 wire will be sufficient, nor if it will fit in 3/4 emt.
Old 06-06-2012, 12:55 PM   #6
Conduit Fill Chart
thought this may help others: http://www.westernextralite.com/resources.asp?key=47
The Following User Says Thank You to frodin1 For This Useful Post:
goosebarry (06-06-2012)
Old 06-06-2012, 01:11 PM   #7
Sparky
Rewards Points: 510
Max fill on #8 THHN in 3/4" EMT is 6
Techy is offline   Reply With Quote
Old 06-06-2012, 06:27 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Air Compressor break down....
5 HP 240V Motor :
Table 430.248 gives us a FLC of 28 amps
Branch Circuit size is to be no smaller than 125%
FLC 28 x 1.25 = 35 amps, Table 310.16 tells us #10 AWG is good for 35 amps at 75*C....
Now for Short circuit and ground fault protection....
For an inverse-time breaker: 28AŚ2.5 =70A breaker....
I would stick with the cord and plug for the plasma cutter....#8AWG, and 50 amp receptacle.
As far as the pipe line, I would install a 1" conduit to a jbox for the receptacle, then pipe over to a disconnect for the air compressor...
The Following User Says Thank You to stickboy1375 For This Useful Post:
electures (06-06-2012)
Old 06-06-2012, 07:24 PM   #9
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
5 HP 240V Motor :
Are you applying commercial thoughts to residential installs? Now you are going to confuse the amateurs I agree with you 100%.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-06-2012, 08:20 PM   #10
Got it, Went and purchased most of everything today. Thanks for the help. I figured the same for the wiring, I just wanted someone to double check me. It's been a while since I've done this and things in this field, and they seem to change often. Thanks again.
Old 06-06-2012, 10:48 PM   #11
E2 Electrician
Not sure what you mean? a motor is a motor regardless where it is installed, The nec dictates everything, so this is the correct answer to the question.
Old 06-06-2012, 10:54 PM   #12
electures's Avatar
I agree with you. It's just that some of our less knowledgable contributors don't grasp this concept. A motor is a motor. Period.
Old 06-07-2012, 11:46 AM   #13
Semi-Pro Electro-Geek
Rewards Points: 2,892
It's worth noting that 70A is the MAXIMUM breaker allowed. It doesn't need to be 70A. Anything 40A or larger should work fine as long as it doesn't trip on startup.
mpoulton is offline   Reply With Quote
Old 06-07-2012, 12:40 PM   #14
Except that for the smaller motors the efficiency and PF vary greatly with motor size. With a 1/6 hp fan motor in an HVAC application only half the Volt x Amps that go in come out again as watts.
Old 06-07-2012, 02:21 PM   #15
electures's Avatar
Unless the motor fails to start and run. In that case the IT breaker can be increased, but can't exceed 400% of the FLA. 4 x 28 = 112. SO a 110A breaker can be used.
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 10:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 07:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
