I am hoping someone can help me. I am updating the wiring in my house. We have a Square D QON30MW150-1 series E8 panel board. Right now there is no room for any more neutral or ground connections. A few of the circuits in the house (probably the original ones) share a neutral. They run all around the house. I am trying to update the wiring in the bedrooms and plan to put in AFCI breakers which can't have a shared neutral. I also would need to ground all the circuits as many are not.
I wrote Schneider for some info on the best way to add a new grounding bar and received this cheerful information, "This load center (QON20MW150-1) that you have is over 25 Years old, and unfortunately we don't have an Installation Manual or any
Instruction sheets, still available, for this Old, Obsolete load center."
I have never seen a load center without the neutral/grounding bars on both sides. This one though only has it on one side. There are two hole left, but not alligned that seem to be where I could add another bar. Would this work? Would it be better (I think it would be better for space reasons and ease of wiring) to put the neutral bar on the other side? What would I need to do to bond the bar to the others if I placed it elsewhere and how would I mount it?
The grounding bar I bought (PK23GTA) says that if no mounting holes are provided to locate the bar on the back of the enclosure, by drilling two .147 (3.7mm) holes. Would I then connect the bar to the others with a 6 guage copper wire? Are there any issues/ things to look for in doing it this way?
I am attaching two pictures, one of the panel, and the second of the neutral lug/bar that shows the holes that are left.
Also every ground wire is in it's own terminal hole. I know on other panels I have seen and been told that you can put two or three grounding wires in one terminal, but never to mix ground and neutral, or put more than one neutral in a terminal. I don't think that would free up enough space, but would it be a good idea to gang together some of the ground wires?
Hopefully I have made sense. If I left out any details please tell me.
Thanks so much
Thanks so much
