Originally Posted by dwoloz
Hi all
I'd like to wire a new receptacle to a bedroom wall but this wall is cantilevered out from the foundation so I can't easily drill through the bottom plate. I could theoretically break out the stucco underneath the bumped out wall then drill with a long auger.
Any advice for this situation would be appreciated. Thanks
If you don't mind the look, you could always use wire mold from an existing receptacle....
or remove the baseboard, and get a wire from an existing outlet....
