Advice - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 09-17-2009, 08:02 PM   #1
Advice
Hey fella's I'm new here and after some advice on wiring, I'm helping a friend (Sam) wire his new house tomorrow which we have just installed and neither of us have a clue as to what wire does what! We have a big black one that sticks out of the ground and Sam got a shock off of it when he touched the metal inside it but I didn't get one when I touched it after he did (we came to the conclusion that he was standing in a puddle and I wasn't) and we also have some wire from inside old extension cords which we are going to use for the lights and power points.
Our plan is to wrap the extension cord cables around the metal on the black wire which sticks out of the ground (we won't be standing in a puddle this time!) and put the other end into the light fittings, my question is what colour (by regulation) does a light need to have (if any) and how many strands of copper does it take to make a light go? We are planning on putting 2-3 strands of copper per wire into each light fitting that way saving on our overall capital cost.
Cheers, any other advice is well needed.
No Limits is offline
Old 09-17-2009, 08:13 PM   #2
New Zealand ?
Wire in the ground? From what ?
This almost seems like a joke
If it isn't please explain why/what you are doing before this is deleted as a joke
No-one here uses extension cords to wire a house
Scuba_Dave is offline
Old 09-17-2009, 08:21 PM   #3
Hey Dave. I called our town coucil over the phone and apparently the black cable is a "230v Mains Cable" and it comes straight from a transformer, I don't know if that means anything to any of you electricians out there but it certainly doesn't ring any bells in my head.
We are going to use extension cord cable because a license is needed over here to purchase cable from a supplier.
Sam came up with a new idea of cutting the cores out of the 230v Mains Cable and connecting them all to one, this way we will have about 5 or 6 copper cores to wrap our extension cord cable around, will this be more efficient ie cheaper in the long run?
Cheers
Old 09-17-2009, 08:28 PM   #4
Here the Main cable MUST go to a meter 1st, as we are charged for power
Maybe you have a meter near the transformer
After the meter wiring then goes to a breaker panel
From the breaker panel smaller gauge wires (depending upon the size of the breaker) are run to outlets, lights etc
There isn't any comaprison to gauge wire & # of strands that I know of
Our wire for the most part is solid core
What about insulation on this wire?
Here we have 1 hot, 1 neutral (white), & a ground wire (bare) all encapsulated in plastic insulation as a single cable
The hot & neutral are also individually coated in insulation 1st
Old 09-17-2009, 08:57 PM   #5
300zx's Avatar
Post
Originally Posted by No Limits View Post
We have a big black one that sticks out of the ground and Sam got a shock off of it when he touched the metal inside it but I didn't get one when I touched it after he did (we came to the conclusion that he was standing in a puddle and I wasn't).
One of you or both are going to end up being DEAD! Hire an electrician that knows what he is doing PLEASE..
300zx is offline
Old 09-17-2009, 09:00 PM   #6
Ah yes...forgot to mention
That 240v line could have easily killed you
Old 09-17-2009, 10:21 PM   #7
Registered User
Termite's Avatar
I'm usually the last person to advocate hiring a pro on this site, but you're in way over your head. If you need help identifying the service cables you stand no chance of safely or correctly wiring that house. Please...Understand that doing a job like this is complex and is better left to those that have a strong understanding of the fundamentals, the code and general electrical safety.
Termite is offline
Old 09-17-2009, 10:23 PM   #8
Obvious fradulent post.
Don't be so obvious next time.
And to the knuckleheads that responded, don't be so gullible
220/221 is offline
Old 09-17-2009, 10:44 PM   #9
IP is from New Zealand......
Old 09-17-2009, 10:46 PM   #10
There are trolls in New Zealand
He is bored, trying to stir something up.
220/221 is offline
Old 09-17-2009, 11:19 PM   #11
Hey guys a few advances in the plan, we decided to dig the cable up to it's source (which ended up being directly under a power line) and pull it out to stop us from getting shocks when we split the copper cores. We used a JCB to pull the cable out from under the power line and a big arc like a lightening strike happened and now it's safe to touch the cable. We've started stripping the copper back from the black cable now and it seems to be going fine, the only problem we have now is how do we go about getting power back to the house?
Is there a quick fix way of re-terminating it back under the powerline?
Old 09-17-2009, 11:51 PM   #12
" Euro " electrician
frenchelectrican's Avatar
I hate to be rude in here but the way you doing you just destory the POCO underground cable and you describe like big arc that is useally is a good short ciruit and I hate to use this word and very loose in here but you are BONEHEAD my Freind live in New Zealand and I know he used work for the POCO and he told me plenty about it.
Expect a POCO fault repair crew comming out to fix your mess there you should done first place is call your POCO to located the cable and mark it out for you.
Now to get the power back by gosh bloody Heck you will have to call the electrician in your area the code is very strict with that.
And if you have triphase supply you are dealing both 240 and 400 volts there { no bullcrap at all on this one btw it the same with French voltage level so I am used to it }
I am pretty sure that is SWA cable and it can be pain in butt to resplice it espcally once you yank it out with your JCB backhoe digger tractour IMO the underground cable is pretty much done for it.
Merci, Marc
P.S. MODS if you want to edit it let me know in PM asap otherwise leave it and this is very serious message to the OP sorry for being harsh but I have good reason to do this.
frenchelectrican is offline
Old 09-18-2009, 12:07 AM   #13
Registered User
Termite's Avatar
I'm closing this thread not due to the responses by responsible posters but due to the overwhelming lack of common sense being exhibited by the original poster. I simply do not believe that this is serious and I don't care to have my time wasted, nor do the other helpful and productive members of this forum.
I fail to believe that anybody is unintelligent enough to do the things that have been described, and if you actually are, we at DIY Chatroom are not going to help you and your friend kill yourselves by messing with line voltage or damage/modify the POCO's system.
Termite is offline
Closed Thread
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 01:55 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 10:16 PM
