Old 12-11-2012, 09:17 AM   #1
addition outlet layout
i am confused with the required outlet wall layout for 2008 codes.
12'betwwen outlets max
any wall 2' needs outlet
how far out of a corner does an outlet need to be?
doors or fireplaces dont count as 6' rule
i am sure i will have more then required but want to make sure the required layout is met....
gwilkrrs is offline   Reply With Quote
Old 12-11-2012, 10:27 AM   #2
JOATMON
ddawg16's Avatar
The intent of the rull is that a lamp with a 6' cord can be plugged in without having to be moved.
I'm going through the same thing now....and in your case is sounds like you have the min covered. But what is more important is that you have them where you really want them.....
I like putting them in places that are easy to get to....think in terms of plugging in a vacuum....where would you want the outlet? If you have a floor lamp....how much furnature do you want to move in order to plug it in?
It's your place....as long as your meeting the minumum...put those babies where you want them....more if fine too....no limit on how many you install.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
The Following User Says Thank You to ddawg16 For This Useful Post:
gwilkrrs (12-12-2012)
Old 12-11-2012, 09:05 PM   #3
I know of no rule that says you have to put them any particular distance from a corner or a door. If the box fits, it ships! I have several that are only a few inches away from a doorway; e.g., you generally want the switch that controls an exterior light to be right next to the exterior door.
fa_f3_20 is offline   Reply With Quote
The Following User Says Thank You to fa_f3_20 For This Useful Post:
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Exterior 50 Amp RV Outlet theatretch85 Electrical 9 11-05-2009 12:07 AM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
