Addition Of Electrical Outlet In A Space - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 03:36 AM   #1
Addition of electrical outlet in a space
I am currently in the process of remodeling a bathroom. My question: How do I add an electrical plug in my bathroom, as the only power source is the wall mounted light fixture above the vanity and the wall switch that operates the light? If any of you have suggestions please pass it on! This is my first time here and look forward to a reply.
Jonn Norman
naishopa is offline   Reply With Quote
Old 10-11-2012, 05:53 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you are in the US, you have to install a new 20A circuit for the bathroom and install a GFI receptacle in the bathroom.
The Following User Says Thank You to k_buz For This Useful Post:
naishopa (10-11-2012)
Old 10-11-2012, 06:30 AM   #3
Addition of Electrical plug
Is it possible to connect the power from the wall lighting fixture and add on the GFI receptacle in the bathroom? I know nothing about electrical work. I just want to know how to simply add an electrical plug based upon the power source (wall lighting fixture) Is this possible?
Thank you!
Jonn Norman
Old 10-11-2012, 06:42 AM   #4
Rewards Points: 2,516
From your description I am assuming the power is coming into the light fixture location.
No ground wires shown for ease of drawing. The receptacle should be a GFCI receptacle.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Old 10-11-2012, 06:45 AM   #5
Below is how a receptacle would be added if the power was coming into the switch location.
Again grond wires not shown.
Old 10-11-2012, 06:45 AM   #6
Licensed electrician
Rewards Points: 1,872
Adding a new receptacle should meet the current code requirements like Kbuz stated in his post, a new 20 amp circuit back to the panel. Tying into the existing light circuit does not meet code.
Help New Addition Electrical Sub Panel/Load RISurfer Electrical 19 07-30-2012 07:34 AM
Ground Wire in Electrical Outlet Box - Where does it go? jgiannis Electrical 3 06-19-2012 02:12 PM
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 11:16 AM
2ft Wall/Hallway Electrical Outlet Question?? hatchekc Electrical 1 07-17-2010 08:51 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
