Adding Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 01:57 PM   #1
adding wiring
can i add a line from an existing outlet to a new ceiling light fixture box. i would like to run the line external to the wall & use BX cable.
bri jo is offline   Reply With Quote
Old 04-13-2011, 04:13 PM   #2
Rewards Points: 1,514
Generally yes. Sometimes you run into complications such as not enough space in the box to connect up the new wires coming in.
Original BX cable is not code compliant. Its spiral sheath is not a good and sufficient ground. Nowadays, most spiral wrapped cabling must have a straight grounding strip or wire running through it.
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 06:52 PM
Wiring Problems sunici Electrical 18 04-26-2009 08:27 PM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 05:04 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
