Adding A Wall Switch To A Closet Light That Was A Pull Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 10:00 PM   #1
Rewards Points: 640
Adding a wall switch to a closet light that was a pull switch
I have a light under our steps where a closet is that was a pull switch light... then the power continues on from there into the rest of the basement...
I want to put a switch on the wall to control a better light instead of a pull switch one..
I read a few years ago that they wanted the NEC to require a neutral at the light switch now, not sure if that happened or not? if so, how would I go about doing this? The old way would of been just run 12/2 to the switch and have the white wire taped black to show its a hot wire switch..
would I need to run 12/3 now and have the hot/netural as they normally are and have the red be the light control like in the simple diagram below?
Or is the 12/2 way still accepted? thanks!
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 02-03-2013, 11:09 PM   #2
" Euro " electrician
frenchelectrican's Avatar
If you have finshed wall then you will have to use the 12-3 but with exposed wall you may have a option to use the 12-2 now and change that to 12-3 later date.
But there is a other option is use the conduit run in 2 conductor plus ground ( if plastique ) and you always can add netural conductor when the time call for it if the motion switch or timer required the netural conductor. ( this can be used either with finshed wall or exposed wall )
The key issue reason why need netural conductor at the switch box due some of the motion sensor or timer will required netural to get function properly. ( check with your switch instruction to see if they do required netural conductor or not )
Merci,
Marc
Old 02-04-2013, 05:58 AM   #3
Rewards Points: 2,516
check with your local code office and see if they have adopted the current version of the NEC barring any exceptions that may be noted as the frenchman has pointed out.
Adding a wall switch to a closet light that was a pull switch-switch-loop-1.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
frenchelectrican (02-04-2013)
Diagram for 3 way ceiling fan light switch Aurora65 Electrical 22 11-27-2012 09:11 AM
Adding a wall switch but found a random "hot" blue wire crzycicada Electrical 8 10-13-2012 05:17 PM
3 way switch adding an add'l light GRed Electrical 2 12-15-2011 04:24 PM
shop light conversion from pull chain to light switch gilbo Electrical 6 03-16-2010 10:49 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
