-   -   Adding a wall switch but found a random "hot" blue wire (http://www.diychatroom.com/f18/adding-wall-switch-but-found-random-hot-blue-wire-159823/)
crzycicada 10-12-2012 08:15 AM
5 Attachment(s)
Hello everyone! I've been a long time stalker but have just now officially joined to hopefully get some more great advice on a peculiar predicament I'm in.
Here's the situation: I am wanting to add a new security light over my garage doors and want to add a light switch to it. There is a mini-breaker box (sub-panel) inside the garage that has 2 20 amp breakers in it and immediately next to it is an outlet. I was hoping to tie into this outlet to wire the switch and then light but when I opened the cover, I found 2 sets of cables (each had a black, white and ground) and a random blue wire. The outlet was wired as such: 2 blacks are wrapped onto the top screw for the hot side, the blue wire was on the bottom screw on the hot side, and then the two whites were on the other side. When I opened the face of the breaker box to see where the heck the blue wire was coming from, it is wired onto the top of one of the breakers. The new wire I've run so far is 12 gauge by the way.
Question: Can I power the new light from this outlet, can I install the light switch also and finally, how do I wire it?
Thank you all for your great help and advice!
Jim Port 10-12-2012 09:23 AM
As someone posted in the other forum stated you should really straighten that mess out before making any changes.
crzycicada 10-12-2012 10:04 AM
Yeah that's on the list of things to do but I wanted to install the security light now as I'll have to hire an electrician to do the sub-panel rewire. The security light is the priority unless of course there's a safety hazard.
Ramone 10-12-2012 03:03 PM
The blue is supplying the power while the doubled up screw blacks are a splice from that feeding something thru the switchbox and to the left.
I agree, clean it up
Oso954 10-12-2012 04:31 PM
Hire the electrician to clean it up.
While he is there, have him add the switch and security light.
Then you will know that it is All Correct..
hammerlane 10-12-2012 05:36 PM
1 Attachment(s)
Originally Posted by crzycicada (Post 1029343)
how do I wire it?
As long as the blue wire is your always hot conductor you can do this.
Ground wires not shown for ease of drawing.
crzycicada 10-13-2012 03:29 PM
You are awesome! This config worked though I didn't add the switch as I'll wait for the electrician to re-wire everything and make it more stream line. At least now everything is working great and we have a security light for when we come home at night! Thank you so very much!!
hammerlane 10-13-2012 05:03 PM
1 Attachment(s)
Buy yourself a switch and a 4" combination duplex/switch raised cover for the 4" square junction box and do the install yourself. Kind of like below but instead of the GFCI the cover is made fr a duplex.
hammerlane 10-13-2012 05:17 PM
1 Attachment(s)
like this
