Adding A Timer To My Outdoor House Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2007, 11:17 PM   #1
Rewards Points: 150
Adding a timer to my outdoor house lighting
I have the typical outdoor house lighting that is builtin under the eves that shines down on the bricks. They are powered by a regular on/off switch in the garage.
Is there something I can use to put those lights on a daily timer? I'd like to have the lights on from say 9:00pm to 6:00am. I saw something at Home Depot where I could replace the switch with a timer but the timer was only good for about one hour. It was just a simple dial timer like you'd see on a dryer.
Any ideas?
ConstantChange is offline   Reply With Quote
Old 03-31-2007, 08:30 AM   #2
Kitchen remodel Guru
A.W. Davis's Avatar
Yes you can do that, in fact I am surprised that HD didnt have any timer switches, I always see them when I am purchasing material for my job sites!
What you want is a digital timer switch.
http://www.epinions.com/content_80092368516
A.W. Davis is offline   Reply With Quote
Old 03-31-2007, 09:56 AM   #3
Electrician
Rewards Points: 780
The link to the above timer is exactly what you need, i have installed one before and they are very nice. You will have to check your current switch and see if the neutral goes through the switch. If there is no neutral in that box and you may be stuck with what you have now.
Your other option would be to install a photocell before those lights, probably at the first light. This way your lights would come on when it is dark and go off when it is light.
darren is online now   Reply With Quote
Adding recessed lighting where old fixture was ConstantChange Electrical 4 01-15-2009 05:42 PM
lighting guideline's - kitchen remodel dcd22 Electrical 3 08-01-2007 12:50 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Digital timer problems bazzer Electrical 4 11-20-2006 06:44 AM
