Adding Three Prong Outlet To Old AC Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 02:00 PM   #1
adding three prong outlet to old AC cable
I have and old house that is wire with the old armor cable, I would like to change the two prong outlets to three prong, can I do that?
sam60 is offline   Reply With Quote
Old 11-19-2011, 07:30 PM   #2
Licensed electrician
Rewards Points: 1,020
It would depend if the AC has a bond strip or not. Without the bond strip AC cable is not a grounding means.
Old 11-20-2011, 05:27 PM   #3
Jim, thank you for the response, But I don't know what a bond strip is. Can you explain it to me.
Old 11-20-2011, 06:19 PM   #4
It is a thin strip of metal in contact with the armor. Look near a cable end and see if you see it backwrapped in the spirals. It may also just be cut off. How old is your cable or house?
Old 11-28-2011, 02:02 AM   #5
Thanks, I found it, the house was build in the late 1950's. I am discovering several issues with the electrical, some outlets and lights, wall heaters are all together in one circuit and it looks like the wiring is 14 with 20 amps circuit breakers and the circuits are not label. I am going to have to do some reading to learn how I can label the circuits. Thanks again
Old 11-28-2011, 02:08 AM   #6
Too Short? Cut it Again!
Is your service on fuses or breakers. You might want to focus on that just to start and first.
Old 11-28-2011, 10:33 PM   #7
They are on breakers and it sounds like yiu are right about starting there. I heard that there was a gadget that you plug in the outlets and you can check in what breaker the circuit is in. Is there such a tool?
Old 11-29-2011, 04:28 PM   #8
You can buy a circuit identifier. A box store probably sells a cheap Chinese thing that may or may not work for $25 or so. The more expensive ones run $50 or more and will suit you better although I have had mixed luck with them as well. Sadly it is a tool that you will probably not need again once you identify your circuits. Unless you would use it elsewhere. They look like this.
You might be better off getting a decent outlet tester you will use again and again and identify things by process of elimination. Or you could go very basic and just use a work light or radio to know when an outlet activates. It will take you longer and a few trips back and forth to the breaker box but you will get the job done.
Old 12-01-2011, 04:32 PM   #9
Rewards Points: 115
you may want to replace 20a breakers with 15a. you do not want overheated wires. unless you can verify 20a's have 12 wire it is best to err on the safe side
pokey is offline   Reply With Quote
Old 12-16-2011, 12:58 AM   #10
Thank you guys for the tips. I was away on a trip that helped me get my mind off the problems with the house, now I have to face reality. Your help is appreciated.
Adding an outlet here? (Pic) CoconutPete General DIY Discussions 10 11-28-2011 09:11 AM
Q on adding a circuit w/ 1duplex and 1 ... uhh single outlet? CoconutPete Electrical 8 10-19-2011 07:39 PM
Adding ceiling fan to switched outlet keeping switched outlet. dhanawa1 Electrical 1 07-06-2011 05:52 PM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 03:06 PM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 10:27 AM
