Old 04-07-2009, 07:56 PM   #1
Question
Adding a switch to Knob & Tube
I want to hang a chandelier to existing knob and tube wiring but there isn't a switch to the electrical source. is there a way to add a pull switch to knob and tube wired to a new chandelier?
john burwell is offline   Reply With Quote
Old 04-07-2009, 08:22 PM   #2
Your local jurisdiction may have the answer to whether or not you can extend or "modify" a knob and tube circuit.
Is the knob and tube insulation brittle? Does it crack?
*Oh, pull switch. Never mind, its simple.
rgsgww is offline   Reply With Quote
Old 04-07-2009, 08:22 PM   #3
dSilanskas's Avatar
If you can find a place on the light to put the pull chain its simple. Splice the neutrals together and the power splices to one black on the pull chain and the black from the light splices with the other black on the pull chain.
dSilanskas is offline   Reply With Quote
Old 04-07-2009, 08:24 PM   #4
dSilanskas's Avatar
I believe he is modifying the light itself not the K&T
Old 04-07-2009, 08:24 PM   #5
I just realized that, edited
Old 04-07-2009, 08:31 PM   #6
Does the new light fixture have 90 degree wiring? Better check, UL listing on the light fixture may say only connect to 90 degree rated wiring....just putting it out there...never done it myself...
unclduey is offline   Reply With Quote
Old 04-07-2009, 10:30 PM   #7
joed's Avatar
Chandelier will probably not require 90șC wiring. The bulbs are not tight to the ceiling where they will create a lot of heat. Be sure to check the install instructions to be sure.
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
knob and tube question marin001 Electrical 7 12-21-2008 04:49 PM
expanding knob & tube wiring jadrma Electrical 12 11-19-2008 05:27 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
