Adding A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 04:47 PM   #1
Mlwhite's Avatar
Rewards Points: 29
Adding a switch
Am trying to add a switch for the light in my laundry room, it is currently a pull chain. I have the switch and box installed and ran the wire to the light fixture. When I undid the light there were two blacks and two whites tied together. The power comes into the light and then the extra set of wire powers the room next to it. How do I wire it so the switch controls only the light in the laundry room.
Michelle
Mlwhite is offline   Reply With Quote
Old 08-07-2011, 05:42 PM   #2
Master Electrician
Rewards Points: 3,826
Leave the white wires connected to the fixture. Disconnect the black fixture wire from the two blacks in the ceiling box. Connect the white wire from the new cable from the switch to the two blacks in the ceiling box. Connect the black of the new cable to the black of the fixture. Connect the the wires of the new cable to the switch. To be code compliant tape or color, with magic marker, the white wire of the new cable. Mark or tape them any color other than green or gray.
brric is online now   Reply With Quote
Old 08-07-2011, 05:58 PM   #3
biggles's Avatar
break the blacks wire nut the switch in and don't forget to pull the chain to the ON position..sorry couldn't resist it....
Old 08-07-2011, 06:19 PM   #4
Mlwhite's Avatar
Rewards Points: 29
Thanks that worked great!!
Michelle
adding new light, to existing switch stiksandstones Electrical 25 03-12-2011 05:50 PM
adding second light from a switch agsurfer Electrical 3 09-10-2010 12:01 PM
adding 2 lights to a switch that powers a light already Limit54 Electrical 5 11-06-2009 11:56 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 12:43 AM
