Adding Subpanel In Attic -- Is This Feasible? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2009, 09:01 AM   #1
Rewards Points: 156
adding subpanel in attic -- is this feasible?
I already have two 20amp circuits running into an attic space but I'm getting really tired of having to go down 2 flights of stairs to turn off breakers. Would it make sense/be ok to just install a subpanel near where both main branches enter the attic and put in two more 20amp breakers to act as a shutoff? I mean, I'd leave the breakers in the panel as well so essentially the circuits would have two breakers each.
jayp is offline   Reply With Quote
Old 05-20-2009, 09:10 AM   #2
Electrical Contractor
Just install two switches.
hpp58 is offline   Reply With Quote
Old 05-20-2009, 09:52 AM   #3
Why do you need to turn them off??
If outlets I'd maybe install a GFCI
Kick the button when you want the circuit off
Old 05-20-2009, 10:09 AM   #4
Rewards Points: 2,350
Just put the grow lights in the basement. The police thermal camera can't see them then, so no need to rush and turn them off...
Old 05-20-2009, 10:56 AM   #5
2 switches would be fine.
paul_arc is offline   Reply With Quote
Old 05-20-2009, 03:08 PM   #6
I don"t care who you are, thats funny
Paelectrican is offline   Reply With Quote
Old 05-22-2009, 09:45 AM   #7
Rewards Points: 156
yes
I guess I thought about using the breakers instead of switches because it seems more of a secure cut than a switch.
Old 05-22-2009, 10:19 AM   #8
Old 05-22-2009, 10:22 AM   #9
Rewards Points: 156
wiring
To do some additional wiring on one circuit. The other circuit is just capped off in a junction box and hasn't even been built out. I guess a subpanel should have been installed but that's not what I have to work with here. Just two 20 amp branches.
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Adding a subpanel BimmerRacer Electrical 20 04-01-2009 08:30 PM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 09:41 AM
Adding attic insulation and cutting soffits a DIY job? drh Roofing/Siding 15 12-31-2007 07:47 PM
Is adding insulation in attic cost effective? AllGoNoShow Building & Construction 1 12-05-2006 11:31 AM
