Adding A Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-01-2009, 03:04 PM   #16
Rewards Points: 109
Originally Posted by wirenut1110 View Post
Yeah that's pretty much the deal. You need a 4-wire because you'll need a neutral. Also, what's the 14/2 for?
Err, I think I meant 12/2. 20A Dedicated bathroom outlet circuit as required by code.
BimmerRacer is offline   Reply With Quote
Old 04-01-2009, 03:06 PM   #17
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Much better
wirenut1110 is offline   Reply With Quote
Old 04-01-2009, 07:56 PM   #18
Rewards Points: 109
Old 04-01-2009, 07:58 PM   #19
Rewards Points: 2,350
The only thing you can power from that feeder is 240 V loads. So, no, you can't use it for the subpanel as you would like. You need a 4-wire feeder.
Old 04-01-2009, 08:17 PM   #20
Rewards Points: 109
So technically I could power just the steam generator unit from it? That would be kind of stupid but would allow me to use the 30' 6/2 cable I bought.
Old 04-01-2009, 08:30 PM   #21
Yes, if you protect the 6-2 with a 50 or 60 A breaker max.
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Adding a subpanel (lots of questions) epeterson777 Electrical 20 02-15-2009 08:55 PM
Determining Main Panel Load with Subpanel added Randell Tarin Electrical 2 04-11-2008 01:21 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
