Adding A Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2013, 10:57 AM   #1
Adding a Sub panel
We just moved and want to bring our hot tub to the new house (its staying at a friends). The new house has a 200 amp main panel but its full can we add a sub panel to the main power or do we need a breaker to the line for the sub? I'm guessing not but wanted to ask before I had an electrican come out
it looks like upgrading the main wouldn't be that bad its on a block wall with the wires behind a removable panel but if I dont have to upgrade the main I dont want to spend the extra cash
I'm in Florida if that helps
Brad
tbirdsc is offline   Reply With Quote
Old 01-09-2013, 11:21 AM   #2
Licensed electrician
Rewards Points: 1,478
A demand load calculation needs to be done to see if your service can handle the new load.
Old 01-09-2013, 04:35 PM   #3
Thanks for the reply
if you mean the load coming into the house I would assume it would (but would verify before doing anything) the house was built in 2005 and being in Florida a pool is always an option even after the home has started construction. This will most likely not be a DIY project I just wanted to get an idea of what will have to be done before I start calling people
If the load is fine for for the extra load can I add a sub box or would the main panel need to be upgraded.
Old 01-09-2013, 04:51 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
If the calculations say you can add a tub, then a sub can be added.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
NJMarine (01-09-2013), tbirdsc (01-10-2013)
Old 01-10-2013, 07:04 AM   #5
so the line to the sub panel doesnt need to have a breaker on it? I used to do car audio and we over fused everything so thats my way of thinking.
I dont plan on a long run to a sub it will be next to the main panel
Old 01-10-2013, 07:17 AM   #6
Lic Elect/Inspector/CPO
The circuit to feeding the subpanel has tobe protected by a breaker. The breaker size is determined by the wire size feeding the subpanel.
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
Old 01-10-2013, 07:18 AM   #7
The feeder for the hot tub will need a two pole breaker in your panel to provide power to the tub. If you do not have space for the breaker you will need to add a subpanel.
Old 01-10-2013, 07:21 AM   #8
Thanks that was really my original question since my main panel is full if the line coming into the house can handle the extra load my main panel needs to be changed for a larger one
thanks everyone
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
Adding a sub panel 250ft away from the main z-man99 Electrical 4 07-19-2009 01:56 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
