Adding Some Overhead Lighting In The Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2009, 02:36 PM   #1
adding some overhead lighting in the basement
I am planning to add some additional overhead incandescent lighting to two rooms in the basement. I have a sufficient quantity of 14-2 NM wire to complete the job. Both rooms are on the same circuit, protected with a 20 amp breaker. Is it safe for me to use this 14-2 wire for the additional wiring or should I get some 12-2 ?
minchu is offline   Reply With Quote
Old 03-09-2009, 02:40 PM   #2
joed's Avatar
Rewards Points: 12,878
You must use 12/2 on a 20 amp circuit. 14/2 is only good for 15 amp circuits.
Old 03-09-2009, 09:53 PM   #3
Rewards Points: 1,512
Is there enough of the 14-2 wire and do you have an empty slot in your panel? You might want to consider the alternative of running a new 15 amp circuit particularly if you are quite decided on incandescent lighting.
Old 03-10-2009, 11:31 AM   #4
Rewards Points: 160
Change out the 20 amp breaker with a 15 amp and install your fixtures. Otherwise you will have to pull a new 12/2 circuit. The choice is yours.
Old 03-11-2009, 09:43 PM   #5
if your existing wires are 12-2, then you should use 12-2. If you use 14-2 then as above statement, change the breaker to a 15 amp. I would use 12-2 and keep the 20 amp because someone down the road may replace the 15 with a 20 not knowing there is 15 amp rated wire on the circuit.
patriot1 is offline   Reply With Quote
lighting for low basement ceiling South Portlander Electrical 16 01-28-2012 06:25 AM
Overhead lighting Run to lights first then switches, 14/3 to both switches? twilightcall Electrical 4 07-10-2008 04:18 PM
Recessed Lighting In Basement Rifeman Remodeling 12 09-06-2007 01:26 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
adding a basement tub drain wibass Plumbing 2 06-09-2007 06:50 AM
