Adding A Second Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 02:03 AM   #1
Adding a second sub panel
My house has a 200 amp service with an exterior cutoff panel adjacent to the meter base. Breaker 1 is 70 amps for exterior AC/Heating circuits. Breaker 2 is 90 amps and controls the interior load center/subpanel.
According to the 2002 NEC load calc, I currently require 80 amps available from the existing 90 being fed to the interior load center.
I got an electrical permit (based on 2002 NEC), and am starting to wire an addition which includes master bedroom, bathroom, laundry, kitchen expansion. Can I add a third breaker to the exterior cutoff panel/load center and run a new SER, 4 wire cable cable to a new subpanel? The addition needs approx 40 amps. Should I use #4 copper for a 50' run through a crawl space?
shizzledog is offline   Reply With Quote
Old 08-09-2009, 09:06 AM   #2
Is there room for another breaker?
I used #6 wire for a 60a sub panel
Have you performed a load calc to determine the 40a load?
What will you have on this sub for power draw?
Adding a Sub Panel for Transfer Switch dcopps Electrical 27 08-24-2009 11:36 AM
Adding a sub panel 250ft away from the main z-man99 Electrical 4 07-19-2009 02:56 AM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 05:52 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
