Adding Second Light From A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2010, 01:24 AM   #1
adding second light from a switch
I'm looking to add a second light from a switch. I currently have this layout. Power source > light > switch. So basically i want this layout. Power source > light > switch > light. The switch controlling both lights. I saw the diagram that was recently posted for two lights situated between the power source and the switch. (power > light > light > switch). I would like to avoid this layout if possible since the switch is going to be between the two lights, and would like to avoid having to replace the existing 2 wire cable.
Thanks..
agsurfer is offline   Reply With Quote
Old 09-10-2010, 01:28 AM   #2
Just call me Andrew
Rewards Points: 1,020
What wires do you have in your switchbox? If you only have 2 wires (probably black and white) you can't do it.
If you have 4 wires (2 blacks and 2 whites) (the whites could be behind the switch in a wirenut) then it's possible.
Andrew
secutanudu is offline   Reply With Quote
Old 09-10-2010, 09:14 AM   #3
joed's Avatar
Rewards Points: 11,988
You need three wires between the first light and the swtich to make this work. You will probably need to change the cable between the switch and the light.
This drawing has three lights after the switch but it is the same. Just cut off the last two light for your situation.
The Following User Says Thank You to joed For This Useful Post:
Lurlene (09-15-2010)
Old 09-10-2010, 01:01 PM   #4
Thanks for the quick replies. It looks like i'll need to change the cables. Thanks for the diagram, a picture IS worth a thousand words.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Adding a light to a 3-way switch Richo Electrical 3 04-05-2009 11:29 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
adding an additional light to 2 3-way switches basement_guy Electrical 10 07-20-2008 10:23 AM
