Old 06-27-2008, 07:11 PM   #1
Adding second light fixture in bathroom
Currently have one light fixture and one switch. Want to add a second light fixture operated by a second switch. Want to locate both switches together (remove single switch box and install double switch). Can I pull power from existing switch and if so, how do I make connections?
upcountryliving is offline   Reply With Quote
Old 06-27-2008, 08:56 PM   #2
Licensed Pro
It may or may not be possible. You will need to look at the existing switch and determine how many wires are in the box, what color they are, and which ones are connected to the switch.
Old 06-28-2008, 05:44 PM   #3
Thanks HouseHelper. Completed the wiring today. Found one set of 12/2 wires which was hot and another set which went to the existing light fixture. Ran my new 12/2 wire for the second fixture, connected everything up and wallah!, everthing works as planned. Appreciate the help.
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
Safety Concern related to bathroom light fixture sooner2k1 Electrical 3 01-10-2008 09:57 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Replacing Bathroom Light Fixture shapeshifter Electrical 1 02-05-2007 05:33 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
