Adding Recessed Lighting To An Existing Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 10:28 AM   #1
Adding recessed lighting to an existing circuit
i have just installed 4 cans controlled by a dimmer switch using 14/2 wire and plan to hook into a 15A circuit. The easiest wire for me to hook into this circuit is on the load side of a receptacle that goes to another receptacle. can I cut the wire that goes between receptacles and split the hot wire so it goes to the new recessed cans ( same for the white wire) and then on to the receptacle as previous?
Tom
Tombmt is offline   Reply With Quote
Adding exhaust fan to existing light circuit EelectricP Electrical 1 08-19-2011 10:31 AM
Branching off existing circuit schnitz411 Electrical 13 03-14-2010 11:11 PM
Adding recessed lighting where old fixture was ConstantChange Electrical 4 01-15-2009 05:42 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 11:21 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
