Adding A Recepticle For Jacuzzi/steam Shower - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2010, 05:42 PM   #1
adding a recepticle for jacuzzi/steam shower
installing a all in 1 piece tub/steam shower it has a 3 prong plug to power it i need thou to add a recepticle (GFI) on the wall where the incloser will go can i just run a wire from a wall switch or jump off a outside recepticl close on the other side of wall
DOGTOWN is offline   Reply With Quote
Old 05-23-2010, 05:44 PM   #2
Where are you located ?
What does the Mfg instructions indicate you need ?
Old 05-23-2010, 05:47 PM   #3
we live in calif we do not have the manual we let a plumber look at it for qoute nand he never returned it i was under the impressing you need it to be a gfi
Old 05-23-2010, 06:10 PM   #4
Does the plug have anything on it ?
Mfg & model of the unit ?
Manual should be on the web
Old 05-23-2010, 06:38 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
It will definitely need GFI and will most likely need a dedicated circuit that is appropriately sized.
Speedy Petey is online now   Reply With Quote
Adding a shower head ideas Pontiacgirl Plumbing 1 01-23-2010 08:56 PM
Adding hand rail to tile shower tns1 Carpentry 5 10-03-2009 12:33 PM
adding recepticle to 14-2 wire JB619 Electrical 6 09-21-2009 09:06 PM
Adding a second shower head? J187 Remodeling 6 03-26-2009 12:16 PM
Adding a shower to a 1/2 bath amyjean Plumbing 1 09-10-2005 08:06 PM
