Adding Recepticle To 14-2 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 08:22 PM   #1
adding recepticle to 14-2 wire
i want to add a recepticle . and get power from a 14-2 wire that is going to a switch, can i cut the wire and add recepticle on that wire
JB619 is offline   Reply With Quote
Old 09-21-2009, 08:31 PM   #2
Is there only 1 cable going to the switch?
If only one then it is only a switched loop - hot line only
Old 09-21-2009, 08:39 PM   #3
Thumbs up
Yes you can. Under certain conditions. If you have a NEUTRAL wire running in the same box. You can do it in either of Two ways. 1) a Combo Switch. Or expand the box and make it into a 2-gang box. The Sw./Receptacle can also be connected in 2 different ways. a) The receptacle should be controlled by the switch. 2) The receptacle is always ON! (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 09-21-2009, 08:40 PM   #4
there is 1 14-2 wire going to switch and switch goes out to 2 light fixtures i want to know if i can splice into ( or cut wire) wire before the switch and add a recepticle
Old 09-21-2009, 08:44 PM   #5
hey spark plug thank you for the reply, but i wanna add a seperate j box for the recepticle , because i need it on the wall behind the switch, does that make sense
Old 09-21-2009, 08:46 PM   #6
If there is only 1 14-2 cable then no
Old 09-21-2009, 09:06 PM   #7
Thumbs up
Yes, you can. Under the conditions we discussed originally. Me and Scuba Dave were giving you the same advice. But from a different end of the equation. Yes, if there's an additional wire/cable (Neutral) in the same box. No. If there's only ONE set of Black and White wires in the box.!!!(No matter what)Don't drink and Drive, Ever!!!
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 10:59 AM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 01:49 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
adding an additional light to 2 3-way switches basement_guy Electrical 10 07-20-2008 10:23 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
