Adding A Receptical - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 09:05 AM   #1
adding a receptical
We removed a receptical when we took out a wall in our kitchen. We want to add a receptical to our island now and would like to use the wire from the removed receptical. However, the removed outlet seems to have been connected to a switch. How do we use the old wire (one red, one black, and one white) and connect it to a wire with one black, one white, and one ground in order to power a receptical? We do not want this receptical connected to a switch.
CyndiLou is offline   Reply With Quote
Old 02-02-2010, 09:10 AM   #2
You will need to bypass the switch
Is there a ground ?
If so you should be able to connect the black, white & ground
Old 02-02-2010, 09:15 AM   #3
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
If you put wire nuts at the old location to connect an additional length of wire, you will have to put it in a junction box that is visible outside the wall. Likewise with the old switch location. It's illegal to hide junctions under walls.
brons2 is offline   Reply With Quote
Old 02-02-2010, 09:30 AM   #4
Adding a receptical
Thanks! I understand about the junction box. However, there is no ground wire on the existing wire.
Old 02-02-2010, 09:34 AM   #5
Is this a 3-way switch ?
You will need to locate an outlet with a ground
Kitchen requires 2 dedicated circuits & GFCI
If you already have 2 then you meet code
But what else is on this circuit that you want to tap into ?
Do you have a basement/crawl space to run a wire
Old 02-02-2010, 09:43 AM   #6
Yes, this is a three-way switch. I thought maybe we would have to locate an outlet with a ground, but just wanted to be sure I couldn't use the old one somehow. We do have plenty of crawl space. I'm just not sure which wire to tap into down there! How can I best choose which line to tap into? I have 2 breakers for kitchen/rec, 1 for Kitchen/GFI/Rec, 1 for freezer, 1 for dishwasher-disposal.
Old 02-02-2010, 09:58 AM   #7
You need to tap into one of the kitchen GFCI receptacle circuits
I wouldn't tap into the freezer circuit
DW/disposal needs its own dedicated circuit
Old 02-02-2010, 10:05 AM   #8
Thanks for the advice!
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
Upsidedown receptical? Giles Electrical 26 01-29-2010 12:07 PM
adding on to an existing detached garage ebstein Building & Construction 4 09-24-2009 11:32 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 11:51 AM
