Adding Receptacles Transition Inside Corner - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 07:58 AM   #1
Rewards Points: 166
Looking at the photo, what I want to do is put a J-Box & duplex receptacle(shown in red) so that I can plug in items on that side of the wall(cable modem & lawn sprinkler) into that duplex.
Also that J-Box(in red) will be used to feed other downstream basement receptacles at a later date.
I'll grab power for the new duplex from the load side of a GFCI. The GFCI is not visible in the photo but is underneath the 6-way adaptor at the lower right side of the panel.
My question is what is the best way span the area in yellow in the photo to run the wire to the new J-Box/Duplex?
Would you use a stub of EMT from the current J-Box/GFCI-------->to an EMT Inside Pull Elbow-------->stub of EMT-----------> new J-Box/Duplex.
Or can flexible metal conduit be used from the current J-Box/GFCI to the new J-Box/Duplex?
Minus08 is offline   Reply With Quote
Old 02-05-2012, 08:02 AM   #2
Julius793's Avatar
I'd use flex, ac, mc, or even nm if I'm in a pinch. Just make sure you use the appropriate connectors.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-05-2012, 08:10 AM   #3
Rewards Points: 166
well I know NM cable is not the right way to do it because of physical protection but I like the idea of the flex
Old 02-05-2012, 08:13 AM   #4
Julius793's Avatar
Well I thought I would add it anyway just because that's what I do on your threads
Old 02-05-2012, 08:15 AM   #5
Rewards Points: 166
don't understand that but what the hay
Old 02-05-2012, 08:30 AM   #6
Electrician
SD515's Avatar
Rewards Points: 504
What about a 90 degree piece of EMT from the GFI box to the new box?
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
jbfan (02-05-2012)
Old 02-05-2012, 09:25 AM   #7
Julius793's Avatar
Well it's kinda a joke remember you first post? And then the other three? but hey it's your house do as you wish.
Old 02-05-2012, 10:52 AM   #8
Rewards Points: 166
Oh yeah you made the troll comment which I still do not understand why my height makes a difference and how you know I'm short in stature?
@SD515: I guess I can see if I can get a piece of 1/2 EMT bent in there. Worth a shot.
Old 02-05-2012, 10:57 AM   #9
Julius793's Avatar
Stop spewing crap, I didn't say anything about your height nor you stature. If you respond to this you will be asking for a thread derailment
Old 02-05-2012, 11:05 AM   #10
Rewards Points: 166
I beg to differ.
In post #9 here:
What Size Ground Pigtails From 10-2 NM cable
You said in part:
For some reason I think you a troll?
So I don't know how you know my stature is vertically challenged.
Old 02-05-2012, 11:08 AM   #11
Julius793's Avatar
I beg to differ. In post #9 here:
You said in part:
Ok your right I did say something about your stature, now what? Still didn't say nothing about your hight!
Old 02-05-2012, 11:13 AM   #12
Rewards Points: 166
It's time to get ready for Super Bowl.
GO PATS!!!
Old 02-05-2012, 11:17 AM   #13
Julius793's Avatar
GO PATS!!!
Now I know why we can never get along!!!!!!!!!!!!!!!!!!!!!!!!!!! Screw the god damn pats!! Sry I am just an arragant newyorker
Old 02-10-2012, 03:10 PM   #14
Rewards Points: 166
thats what I did just bent a piece of EMT. forgot to buy the 4 inch box cover that holds the outlet so cant finish yet
Old 02-10-2012, 04:19 PM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
You could have bought a premade 90 and not have that cink.
adding wall insulation inside or out? jgreaves General DIY Discussions 1 09-26-2009 05:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Adding two receptacles off of one sploinker Electrical 7 09-10-2008 12:14 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 12:35 PM
