Adding Receptacles In Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 07:43 PM   #1
Adding receptacles in garage
I'm trying to add receptacles into my garage as I'm currently limited to a single GFCI.
I have a two-story house with the garage underneath one of the bedrooms, so I don't have any access to run romex in the ceiling/attic space. The sub-panel with breakers for all the branch circuits (duplexes/light fixtures/etc.) throughout the house.
Here is what I'm hoping to do - feel free to burst my bubble or point out what you might see as a problem:
- feed Romex through the bottom of the panel (flush mount) down the wallspace
- come out of the wall below the panel using a wiremold box to feed into a small surface raceway to feed the receptacles I want to add
I can handle the surface raceway part... my concern is that I'll hit a snag with what I want to do with coming out of the panel through the bottom.
I realize I'll have to take the cover off to see what I have to work with.
All that said, can anyone think of anything that could cause me grief? I want to be aware of as much as possible before I start this.
Thanks!
brich is offline   Reply With Quote
Old 02-25-2010, 05:55 AM   #2
Surface mounted wiremold is usually OK. If you don't feel you are up to the task of connecting at the panel, get a pro. And don't forget the inspection.
Old 02-25-2010, 11:05 AM   #3
Rewards Points: 756
If I were an inspector, I would not accept wiremold in a garage at any height that it could be damaged by a vehicle (doors, bumpers, etc).
Mark
busman is offline   Reply With Quote
Old 02-25-2010, 04:57 PM   #4
Journeyman Wireman
Rewards Points: 150
Whether Wiremold is acceptable in a garage is up to the individual jurisdiction. It is an acceptable wireway as long as it is rated for the location and as far as I know Wiremold is fine anywhere as long as it's a dry location.
Jupe Blue is offline   Reply With Quote
Old 02-25-2010, 06:59 PM   #5
Mark
I hadn't even thought of that - but that is a good point. Fortunately my house is on a slight incline. The garage has approx. 18-24" of foundation concrete AFF inside the garage. I was actually going to be mounting even higher than that, so if we were to ever use our "2" car garage for vehicles it would be out of the way.
Old 02-25-2010, 07:59 PM   #6
right don't forget the inspection. lol
longbeach1125 is offline   Reply With Quote
adding on to an existing detached garage ebstein Building & Construction 4 09-24-2009 10:32 PM
Adding A Garage kmb997 Building & Construction 4 07-17-2009 03:28 PM
Adding Service to Attached Garage SyracuseSteve Electrical 13 03-23-2009 12:20 PM
Adding two receptacles off of one sploinker Electrical 7 09-10-2008 12:14 PM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 04:44 AM
