Adding Receptacle Questions - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-05-2009, 01:40 PM   #16
Rewards Points: 820
Do you think it's OK to use a 15A breaker for the central vac, which draws 12A?
I'm not sure what the code says about continuous load vs breaker size, but I personally would run #12 cable on a 20A breaker.
Ultrarunner2017 is offline   Reply With Quote
Old 01-05-2009, 02:23 PM   #17
Originally Posted by drtbk4ever View Post
Great catch.
That is the ground wire that the Cable Guy disconnected when I was having issues with my cable reception. It was connected to the main panel ground wire and is now just hanging in space. He said it was possible my cable was picking up interference off of the wiring in my house through this ground wire.
Do you think I should reconnect it?
Yes, and you could install an isolator for the cable system.
This is the one I have, and recommend
http://www.amazon.com/Viewsonics-VSI.../dp/B0017I3K9M
Just install it right after the ground block, or before your amp/splitter to tvs.
rgsgww is offline   Reply With Quote
Old 01-05-2009, 02:25 PM   #18
I don't think someone would use central vac for 3+hours.
If the distance is long, I would run 12 awg on a 15 or 20 breaker.
14 on a 15 is for this is ok.
Old 01-05-2009, 03:02 PM   #19
Newbie Bill
Rewards Points: 518
Now you guys tell me I should have run 12 and a 20 breaker. However, I have already ran 14 wire and put it on a 15 Amp breaker. It may not be ideal, but is a heck of a lot better than running it off an extension cord plugged into an outlet is also running a refrigerator.
Thanks for the link on the isolator
drtbk4ever is offline   Reply With Quote
Old 01-05-2009, 04:26 PM   #20
No, I would have ran 14 awg any day.
I was saying that 12 awg was overkill. 14 awg is ideal.
The nec has a load sizing requirement for loads lasting longer than 3 hours, such as lighting. A central vac is not a 3 hour load.
Your welcome.
Old 01-05-2009, 04:30 PM   #21
Electrician
Yes, because its legal, check out 210.23 (A)(1)
chris75 is offline   Reply With Quote
Questions About Changing GFCI receptacle to a normal three pronged outlet LYTTONJ Electrical 11 05-04-2011 03:23 PM
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 06:36 PM
Adding a Hot Receptacle to a 3-Way Switch rtyui2 Electrical 11 11-21-2007 09:08 PM
Adding a receptacle to existing circuit dekohl Electrical 3 09-10-2007 02:46 PM
