Adding A Receptacle From Existing Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 05:17 PM   #1
Rewards Points: 16
Adding a receptacle from existing switch
Im putting a closet under my staircase and want to add a light with a switch in the closet and a receptacle on the wall. There is an existing switch that powers a light in the hallway near the stairs. It looks like the white is just part of the switch loop.
themow is offline   Reply With Quote
Old 11-13-2011, 05:27 PM   #2
Rewards Points: 582
that would be my guess as well only 2-wires for switching.....nuetural in another box.
Old 11-13-2011, 06:38 PM   #3
Licensed electrician
Rewards Points: 1,456
The white in the switch box should be the constant hot. There is no neutral in that box.
Old 11-13-2011, 08:03 PM   #4
joed's Avatar
Rewards Points: 12,334
You can't get you power from the switch for the reasons stated above. There is no neutral. It is a switch loop.
Old 11-13-2011, 08:46 PM   #5
Rewards Points: 16
This is the junction box that goes to the light and the switch (It intercepts them). BX cable? Tie the hot into the hot and the neutral into the neutral and the ground to the screw on the junction? I guess that white tied in with the hots was for that light switch loop? Am i good to go? forgetting anything? Thanks
Old 11-13-2011, 10:10 PM   #6
The box is already overfilled. You need a larger box.
Old 11-13-2011, 10:34 PM   #7
Electrician
SD515's Avatar
Rewards Points: 504
And secure it to the building, not just let it ‘float’ in the air. (Notice the sprinkler head in the first picture, Jim?)
Kyle
Old 11-13-2011, 10:34 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
Were you planning on using Romex (NM cable) with that plastic nail on box? Is that allowed in your area? You can’t use that plastic box if you were going to use MC cable (similar to the BX cable shown in the pictures).
Kyle
Old 11-14-2011, 08:16 AM   #9
Rewards Points: 16
Id be using romex. I dont have any armored cable.
I will secure the box. That is the way they do things in this building. Quite frustrating to see.
Existing switch, replace with combo switch/outlet shujinko Electrical 4 04-30-2011 05:19 PM
adding new light, to existing switch stiksandstones Electrical 25 03-12-2011 05:50 PM
Switch / Receptacle mikbro Electrical 11 10-31-2008 04:15 PM
3 way switch - adding in a switch jamiedolan Electrical 4 10-23-2008 11:35 AM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 06:57 PM
