Adding Receptacle On Existing Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2009, 12:23 PM   #1
Adding receptacle on existing circuit
Hi all-
Adding some undercabinet puck lighting and want to check on how to best add it to the existing circuit.
My plan is to replace an existing box with a single pole controlling my overhead kitchen light with a double-gang box with two single-poles...one for the existing and a second for the lighting. The location of the box is about a foot from the where the lights and their transformer are actually going.
The existing setup in the box is:
Set 1 in/out: Black/Red/White
Set 2 in/out: White/Black
The existing switch gets the red on one terminal, which is the end of the run on that red, and the black on the other terminal, which is one branch off a nut, the other one of wihch keeps going out. The white goes in and via a nut straight out.
Would appreciate any help on how to add in the new switch, obviously intended to be controlled totally seperate from the existing switch.
schnitz411 is offline   Reply With Quote
Old 08-12-2009, 01:26 PM   #2
Your new switch leg will be black/white.
In the new 2 gang box,
1) wirenut all whites together.
2) wirenut existing blacks along with two pigtails which will provide power the two switches.
3) Install one pigtail to each switch. Install existing red to one switch, (new) black to the other.
220/221 is offline   Reply With Quote
Old 08-12-2009, 06:15 PM   #3
Worked perfectly thanks!
Only challenges were dealing with a new work box that was attached to a stud that couldn't be undone without more holes in the drywall and making pigtails...which I don't seem to have mastered.
Adding a room, tie in to existing framing rampeyboy Building & Construction 4 12-26-2008 04:16 PM
Adding Kitchen pass through to an existing opening? sscott0203 Remodeling 7 12-13-2008 04:17 AM
Adding a circuit mholmen Electrical 10 07-23-2008 12:36 PM
adding window casing/moulding to existing windows Indy_Steve General DIY Discussions 6 01-27-2008 03:58 PM
adding to existing insulation renegade Building & Construction 2 01-23-2008 11:46 PM
