Adding Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2010, 04:56 PM   #1
Rewards Points: 109
adding receptacle
My basement lights are on a 15 amp breaker. I want to add a receptacle off of one of the lights that has 14/2 guage wire. What guage should I use for the receptacle?
hitmehhh is offline   Reply With Quote
Old 09-15-2010, 05:07 PM   #2
liscenced electrician
Rewards Points: 538
errrrrr wait, what? 14/2, but keep in mind if you come off the light, it will only be hot when the lights are turned on
jimmy21 is offline   Reply With Quote
Old 09-15-2010, 05:58 PM   #3
Mad Scientist
Unless you have pullchain only lights, like I do. Then you're good to go. But if they're on a switch, then yes, probably you'll end up with an outlet that only works when the switch is on.
McSteve is offline   Reply With Quote
Old 09-15-2010, 06:04 PM   #4
Also depends if power was run to the light 1st...or the switch
Old 09-15-2010, 06:43 PM   #5
Rewards Points: 109
Yes , it is off of a pullchain light. I'm done and it works fine.
Adding a receptacle in the basement Bigplanz Electrical 1 11-11-2009 05:31 PM
Adding an outdoor receptacle Mr. Michael Electrical 4 04-14-2009 09:42 PM
Adding receptacle questions drtbk4ever Electrical 20 01-05-2009 03:30 PM
Adding a Hot Receptacle to a 3-Way Switch rtyui2 Electrical 11 11-21-2007 08:08 PM
Adding a receptacle to existing circuit dekohl Electrical 3 09-10-2007 01:46 PM
