Adding To A Plastic Switch Box - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 02:14 PM   #1
Adding to a plastic switch box
See picture.
I need to add a timer switch next to the existing light switch for a fan. I planned to just add another box to the right of the existing box. However, the existing one is plastic, thus, I can not detach just the right side of the existing box and tie in a new box.
I also don't want to replace the single switch with 2 switches in the same box. The fan timer switch has 6 different options on it; it take up a box by itself.
Is there a way to solve this without cutting into the wall above and below the existing switch to get to the nails that hold that existing box in place? Yes, I could mess up the wall this much, and then just add a 2 gang box, but I am trying to see if there is a 'less intrusive to the wall' alternative.
Thanks.
jdjd is offline   Reply With Quote
Old 06-25-2012, 02:19 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Assuming the stud is on the left, cut the drywall to the right of the box enough to add a 2 gang box. Use a flat bar (or a large screwdriver) to pry the existing box away from the stud (1/4" is enough). Cut the nails with a saws-all or a hack saw blade.
Coastal South Carolina
Old 06-25-2012, 02:35 PM   #3
Or cut in a remodel box several inches away from the existing in the same stud bay and jump the conductors from the old to the new.
Evstarr is offline   Reply With Quote
Adding new GFCI outlet to existing light switch idzrvit Electrical 15 11-20-2011 09:16 PM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 12:43 AM
