Adding Outlets For Top Of Wall Mounted Upper Kitchen Cabinet - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 09:37 AM   #1
Adding outlets for top of wall mounted upper kitchen cabinet
Hi,
First part...
I want to run off an existing 15A circuit a new switch and four outlets to power ONLY 5 strings of rope lites for cabinet top lighting. These will be placed on the top of each cabinet bank and each outlet will be off the same switch.
If my math is correct, I have 1800W capacity.
Each string has 72 bulbs, each bulb is 0.25 watts. that makes each string 0.15A * 5 strings = 0.75A draw when all on.
The existing circuit only currently powers 4 60W light fixtures in the unfinished portion of my basement and a motion light on the back porch with two 90W floods.
So there is another 240W + 180W = 420w/120v = 3.5A
so if everything is on at the same time, I'm only at about 4.25A draw.
Does this sound ok?
Second part ....
I don't find anything in NEC that says this is not appropriate?
Again, these are 6 ft strings of rope light by Utilitech and will be affixed to
the top of wall mounted cabinets
Third part....
I plan to just wire these in parallel off a junction from the cellar underneath. (Junction -> switch -> outlet->outlet>outlet>outlet)
14/2 -> switch (BLK in, BLK out, tie WHT together, ground to switch) ->
-> 14/2 in from switchbox to first outlet, BLK/WHT in, BLK/WHT out to next outlet) -> 14/2 in to second outlet , BLK/WHT in, BLK,WHT out to next outlet) -> repeat for the next 2 outlets.
I want the entire outlet to be switched, so I am NOT removing ANY tabs.
Does this look ok?
tmorriss is offline   Reply With Quote
Old 02-24-2011, 07:01 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Looks good!
jbfan is online now   Reply With Quote
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
filler on kitchen cabinet timbo59 Carpentry 7 05-05-2010 08:19 AM
Kitchen Cabinet Toekick color cellophane Interior Decorating 3 10-29-2009 03:52 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
