Old 09-22-2010, 10:35 PM   #1
Adding outlets to front porch
Ok I am considering adding outlets to the front porch which is Covered and will be adding 2 outlets, Can I tie into a junction box in the basement and run from there in the outlets, or from the pro's whats the best way..
Splinter2
splinter2 is offline   Reply With Quote
Old 09-22-2010, 10:45 PM   #2
" Euro " electrician
frenchelectrican's Avatar
I would run it own circuit if you have room in the load centre and be aware that you will need RCD { GFCI } anyway.
And you may end up get WP cover as well if you will get some water get into the device.
Is the porch is all screen or complety enclosed ?
Merci.
Marc
Old 09-23-2010, 09:09 AM   #3
Just call me Andrew
Depending on what is on the circuit that is feeding the J-Box in the basement, you may be able to legally tie into it. Is your basement finished? If not...I'd run a new circuit. You never know what you may plug in there.
And like Marc said - you will need both outlets to be GFCI protected, but only the first one in the chain needs to be a GFCI, it can protect the second one.
Andrew
secutanudu is offline   Reply With Quote
Building a front porch and have questions... SolidStateS15 Building & Construction 9 07-10-2010 05:16 PM
under front porch lattice 4just1don Building & Construction 1 06-03-2010 03:17 PM
New Circuit to outside front porch - need help Leah Frances Electrical 12 05-13-2010 04:12 PM
adding a porch to existing house jeanien Roofing 2 08-21-2009 01:52 PM
Ideas for adding porch roof...pics! jcrack_corn Roofing 4 06-22-2008 12:30 AM
