-   -   Adding outlets to front porch (http://www.diychatroom.com/f18/adding-outlets-front-porch-82103/)
splinter2 09-22-2010 10:35 PM
Ok I am considering adding outlets to the front porch which is Covered and will be adding 2 outlets, Can I tie into a junction box in the basement and run from there in the outlets, or from the pro's whats the best way..
Splinter2
frenchelectrican 09-22-2010 10:45 PM
I would run it own circuit if you have room in the load centre and be aware that you will need RCD { GFCI } anyway.
And you may end up get WP cover as well if you will get some water get into the device.
Is the porch is all screen or complety enclosed ?
Merci.
Marc
secutanudu 09-23-2010 09:09 AM
Depending on what is on the circuit that is feeding the J-Box in the basement, you may be able to legally tie into it. Is your basement finished? If not...I'd run a new circuit. You never know what you may plug in there.
And like Marc said - you will need both outlets to be GFCI protected, but only the first one in the chain needs to be a GFCI, it can protect the second one.
