Adding Outlets To Existing 15A Lighting Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2011, 05:41 AM   #1
Adding outlets to existing 15A lighting circuit
In my basement workshop I have four 2'X4' troffer (lay-in) type fluorescent light fixtures on a 15 amp circuit with 14/2 and 14/3 NM with a single pole switch.
Each lighting fixture contains two T12 magnetic ballasts that pull .73 amps each - which totals a little under 6amps for all four lights.
I would like to add one (or more?) ceiling outlets between the light fixtures.
Would that be permissible? If so, how many?
Thanks in advance for your help.
rstain is offline   Reply With Quote
Old 11-29-2011, 07:31 AM   #2
It is not good practice to have lights and outlets on the same circuit(if a circuit with both goes out, you are left in the dark), but not sure if it is not allowed under code, check local code.
Old 11-29-2011, 08:47 AM   #3
joed's Avatar
Rewards Points: 11,608
There will be no code issues with doing this.
Old 12-03-2011, 11:30 AM   #4
Rewards Points: 115
what would outlets be used for?
pokey is offline   Reply With Quote
Adding an outside lamp to a circuit??? CoconutPete Electrical 5 07-26-2011 04:54 PM
Adding outlets for top of wall mounted upper kitchen cabinet tmorriss Electrical 1 02-24-2011 08:01 PM
No power to all outlets on circuit. noloawarfare Electrical 4 05-01-2010 05:41 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
? on 20A circuit / outlets / #of remhed Electrical 2 05-15-2005 09:55 AM
