-   -   Adding outlets to existing 15A lighting circuit (http://www.diychatroom.com/f18/adding-outlets-existing-15a-lighting-circuit-124961/)
rstain 11-29-2011 05:41 AM
In my basement workshop I have four 2'X4' troffer (lay-in) type fluorescent light fixtures on a 15 amp circuit with 14/2 and 14/3 NM with a single pole switch.
Each lighting fixture contains two T12 magnetic ballasts that pull .73 amps each - which totals a little under 6amps for all four lights.
I would like to add one (or more?) ceiling outlets between the light fixtures.
Would that be permissible? If so, how many?
Thanks in advance for your help.
Just Bill 11-29-2011 07:31 AM
It is not good practice to have lights and outlets on the same circuit(if a circuit with both goes out, you are left in the dark), but not sure if it is not allowed under code, check local code.
joed 11-29-2011 08:47 AM
There will be no code issues with doing this.
pokey 12-03-2011 11:30 AM
what would outlets be used for?
