Adding Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 03:16 PM   #1
Adding outlets
I'm new to home owning and even newer to electrical work. My basement has a few outlets, but not where I need them. I'm currently running a tv, game system, cable box and reciever off of a power strip that is plugged into a simple 9ft extension cord. I'm wondering what wire I need to add another plug and how to make sure I won't pop a fuse.
Cheers, New guy
jeff601307 is offline   Reply With Quote
Old 12-03-2011, 03:26 PM   #2
Rewards Points: 6,652
Post a floor plan, and picture of your current electric panel. Also, is this space finished or unfinished. You can use surge strips, and the longest that I would ever use is a 6 ft, 12 ft at the extreme, but only for temporary use.
Old 12-04-2011, 07:19 PM   #3
I don't have an exact floor plan but this is the basic idea. The basement is half finished, half unfinished. I can directly access the back of the outlet currently holding the extension cord for all the devices and the space where I want to place another one. I hope the pictures help, and thanks for taking your time to help out a noobie
Old 12-04-2011, 07:28 PM   #4
If you can not place a drop behind the finished wall, you can use wiremold, which attaches on the outside of the wall, and can be painted. Then you would just use thhn in the wiremold. You would have to place boxes at least every six feet around the perimeter. The good thing is, you can also use wiremold for low voltage wire, such as telephone, catv, ethernet.
As for your panel, it appears to be a older SquareD sub-panel model, but really can not tell, due to how far the shot was.
Old 12-05-2011, 08:01 PM   #5
Any way to know what kind of wiring I would need to support all the electronics that would be using that outlet?
Old 12-05-2011, 08:10 PM   #6
#14 Romex or #14 THHN/TWHN, if you use the wiremold, on a 15 amp circuit.
Old 12-06-2011, 04:23 AM   #7
Rewards Points: 1,192
Remember the N.E.C. Code requires all new circuits to be on an a.f.c.i. breaker.
bobelectric is offline   Reply With Quote
Tags
basement electrical , electrical
question about adding outlets to my basement jtkirk Electrical 12 09-26-2011 09:37 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
Adding outlets for top of wall mounted upper kitchen cabinet tmorriss Electrical 1 02-24-2011 07:01 PM
Adding outlets to front porch splinter2 Electrical 2 09-23-2010 08:09 AM
Advice needed for adding grounded outlets in old home Cool user name Electrical 13 08-30-2010 07:10 PM
