Adding An Outlet- Where's The Cavity? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2012, 11:04 PM   #1
Rewards Points: 81
Adding an outlet- Where's the cavity?
We have a coax outlet in our bedroom but it's not where we want it. I need to add a new outlet. I would like the outlet to be higher on the wall so it's hidden by the TV. I am thinking of an electrical outlet too. This is an inside wall.
What's the best way to accurately drill a hole from the basement into the wall cavity?
Is it a problem to have coax and electric running near each other?
Total Tool is offline   Reply With Quote
Old 09-01-2012, 11:48 PM   #2
An old Tradesmen
Rewards Points: 7,328
Moved to Electrical forum.
Old 09-02-2012, 07:40 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Take a measurement from something known that goes straight into the basement. Heat/AC duct, plumbing pipe, laundry chute. If all else fails, take a small drill bit and drill down at the edge of the wall and look for the bit in the basement.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
rjniles (09-02-2012), Total Tool (09-02-2012)
Old 09-02-2012, 10:46 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
A coat hanger cut at an angle will drill a nice hole next to the baseboard.
The Following User Says Thank You to jbfan For This Useful Post:
stickboy1375 (09-02-2012)
Old 09-02-2012, 01:18 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I use the insulation supports, I keep a box of them on my truck...
Adding An Outlet Off Of Switched light austinbblock Electrical 4 07-23-2012 12:16 PM
Adding overhead light from outlet adgjqetuo Electrical 5 05-28-2012 08:01 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Q on adding a circuit w/ 1duplex and 1 ... uhh single outlet? CoconutPete Electrical 8 10-19-2011 06:39 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
