Adding Outlet Undersink - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2014, 11:00 AM   #1
Adding outlet undersink
Replacing an Insinkerator with a Waste King unit. Insinkerators are hardwired and Waste Kings are plug and play.
My 12-2 NM is currently exposed and hardwired to the bottom of the old disposer with no conduit or metal sheathing.
I'm going to take the existing NM and run it through rigid metal conduit where it is exposed from the wall to the new metal 1 gang box.
The NM comes out next to the main sink drain (shares the same whole in the back wall of the cabinet) Here are my questions...
The NM will enter the conduit in the wall (bushing used) and then continue to the metal gang box. Since the box will not be grounded via the conduit to the main panel I need to ground it using the ground from the line service. I would pigtail the grounds and use a #12 ground wire to ground to the outlet and then off to the box.
Is this the proper way to ensure both the outlet and metal box are grounded?
poorboy01 is offline   Reply With Quote
Old 02-24-2014, 11:14 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 656
Why do you feel you need the conduit?
You are correct in your understanding of the grounding.
Old 02-24-2014, 11:33 AM   #3
Honestly, I just got done wiring my basement (800 sqft) and read everything I could get my hands on regarding properly adding circuts and so forth. I added 8 circuts and did everything to code and probably above (so says my retired electrician friend who oversaw everything i did).
For the life of me as detailed as the NECs are I don't believe it's a requirement for undersink outlets to have their NM housed in conduit or to be GFCI protected.
I think it looks more profesional and is practical in nature to run it in conduit.
My wife stores cleaning supplies and is constantly in that area retrieving items...just seems like it should be protected and sercure.
BTW, is that a big Red in your picture?
Old 02-24-2014, 11:39 AM   #4
jbfan's Avatar
Rewards Points: 656
Nope, Bass pro shop.
If you just want the wire concealed and tucked out of the way, just use some carflex, plastic conduit, but you have the correct understanding.
Old 02-24-2014, 11:44 AM   #5
Ok, I will look into the carflex...
I was wondering about the fish picture...is that a red drum?
Old 02-24-2014, 01:37 PM   #6
jbfan's Avatar
Rewards Points: 656
Sorry, no that was a striper!
Adding new receptacles/ outlet federer Electrical 19 01-24-2013 03:14 PM
adding a switch to an outlet with two circuits jeffpeter Electrical 16 12-10-2012 08:38 PM
Adding An Outlet Off Of Switched light austinbblock Electrical 4 07-23-2012 12:16 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
