Old 07-20-2011, 11:24 AM   #1
Adding an outlet to a switched circuit?
I want to ad an outlet to a switched circuit in a master bedroom. Which wires typically do you pull from? I don't want the new outlet to be switched.
Thanks,
Jeff
bajajeff is offline   Reply With Quote
Old 07-20-2011, 12:02 PM   #2
J. V.'s Avatar
Use the wire that's hot all the time. Plug a lamp into the receptacle and find the switched and the un-switched wires.
The Following User Says Thank You to J. V. For This Useful Post:
bajajeff (07-20-2011)
Switched Outlet Issue mjm Electrical 11 01-23-2011 08:41 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Few questions about adding outlet in unfinished basement McSteve Electrical 14 02-21-2010 11:17 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Help Help richie02 Electrical 7 06-17-2008 09:42 AM
