Adding Outlet Off Three-Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2013, 07:16 PM   #1
Hi there, running into problems with my current project. I'm wondering if I can add my new outlet wire to this existing three way switch. Please find photos attached.
Thanks.
lebleu29 is offline   Reply With Quote
Old 07-22-2013, 11:34 PM   #2
" Euro " electrician
frenchelectrican's Avatar
There are some issue tu will see it.,
First of all which side of three way circuit are you doing ? on supply side or load side but I feel that you are on load side.
Then genrally it much easier to just run a new cable to the load centre instead of mess around with switch box due some case you will not able use the recpectale.
I can tell this is a Canadian verison so the games can change a little.
( Note I did note your screen name is in French so if you want me to reply in French I can do that.)
Merci,
Marc
Old 07-23-2013, 10:21 AM   #3
joed's Avatar
Rewards Points: 13,718
It looks like you have a switch loop.
What I see is power coming in on the white and being fed to the second switch on the black. Travellers coming back as red and white. Then switched power going back to the light on the black.
There is no neutral wire to be used for the receptacle. Find another source of power for the receptacle.
Tags
outlet , switch , three-way
Adding Light Switch - Outlet - Light > Correct wiring ? westbank Electrical 4 09-15-2012 10:42 AM
Adding an outlet from a switch skdiy Electrical 18 01-15-2012 04:12 AM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
