Adding An Outlet Off Of Switched Light - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 11:59 AM   #1
Adding An Outlet Off Of Switched light
I need to add an outlet in my bathroom where i only have a switch and light. The house was built in the 70s and has original wiring. I was planning on adding a box kinda close to the switch...i have complete access on the other side and can see the switch box. My problem is i know how to add one with regular wiring but this light switch has only two wires coming in...one black and white...no ties or splits. At the light in the wall there are ties. I have new wire, an outlet, ties, tools and more.
austinbblock is offline   Reply With Quote
Old 07-23-2012, 12:05 PM   #2
Licensed electrician
Rewards Points: 1,620
The wiring at your switch is called a switch loop. You do not have a neutral which is needed for the receptacle in that box. You have a constant hot and a switched hot.
Old 07-23-2012, 12:07 PM   #3
So the nuetral didnt go through the box, it went straight to the light?
Old 07-23-2012, 12:13 PM   #4
Master Electrician
Correct
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-23-2012, 12:16 PM   #5
Thanks. I found some diagrams online
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Adding a light switch in paralell off of aduplex outlet in a 2 gang box Katsry Electrical 2 11-02-2011 08:56 PM
Adding additional light fixture to switched circuit woodardhsd Electrical 5 07-07-2011 09:06 PM
Branching off Switched Outlet BaconK5 Electrical 7 01-22-2010 05:56 AM
"Split" wire in junction box to outlet and light froddan Electrical 6 12-07-2009 11:32 AM
