Adding Outlet From Light Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-05-2009, 09:43 PM   #16
DIY'r
ScottR's Avatar
Originally Posted by InPhase277 View Post
I guess I didn't read that much. But in your pic, one switch is powering the other. What use is that? A pic from the OP would help alot.
That's what I'm saying... can't figure out the point at all.
Yeah, tad, if you're still around can you post a pic just to keep us from going nuts?
ScottR is offline   Reply With Quote
Old 06-05-2009, 11:20 PM   #17
tad
Sorry couldn't post this sooner. Thanks again for the help.
I've got some pictures of the box before I moved anything... other than pulling the switches out so I could take 'em apart. Glad I took the pics.
In case it isn't clear: the switch on the left is #1. It had the red and white wires attached from the feed.
Switch #2 is on the right. It had the black wire directly from the feed and a short black between it and switch #1. That's it.
adding outlet from light switch-crazywires.jpg   adding outlet from light switch-crazywires2.jpg
tad is offline   Reply With Quote
Old 06-05-2009, 11:25 PM   #18
DIY'r
ScottR's Avatar
That clears it up! The only downside is that InPhase had the correct diagram. That's why he gets paid the big bucks, and me not so much..
Seriously though, the black wire in the switch on the left is back stabbed, so it connects to the white wire. (That's not a good connection, BTW). The switch on the left is not a 3-way.
So white is hot and the black and red go to 2 lights. Unfortunately you have no neutral there, so you still can't tap a receptacle from that box.
Sorry for all the confusion!
PS - Need to ground those switches, and probably the box too.
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Replacing light switch in series wired home - help! kellykate Electrical 6 04-16-2009 06:37 PM
Adding Ceiling Light To Switch vboz5 Electrical 11 03-13-2009 11:09 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
