Adding Outlet To Existing Circuit. Which Way? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 02:50 PM   #1
Rewards Points: 590
Adding outlet to existing circuit. Which way?
I want to add an additional electrical outlet to a circuit. Existing Romex on the circuit runs in the attic down the wall.
There are 2 options as I see it, since there is no slack in the existing Romex. Use 2 junction boxes in the attic to splice in to the existing outlet's romex or pigtail off the new outlet and use one junction box.
Thoughts and suggestions?
noone is offline   Reply With Quote
Old 06-30-2011, 03:06 PM   #2
DIY staff
Rewards Points: 7,174
Either one will work just fine----I like #2 better ,but the cable might be stapled and impossible to remove.
Your call---both are safe.
Old 06-30-2011, 03:17 PM   #3
Rewards Points: 590
Yeah, option 2 is doable, just harder.
Thanks for the verification.
I just wanted to make sure there wasn't some other way that was slipping past me.
I might get lucky with some slack on the line, who knows.
The Following User Says Thank You to noone For This Useful Post:
oh'mike (06-30-2011)
Old 06-30-2011, 03:50 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Are you installing a receptacle above the exsisting receptacle?
Just cut a hole for the new receptacle, drop a new romex to the exsisting box and make connections there.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Old 06-30-2011, 04:05 PM   #5
Licensed electrician
Rewards Points: 1,876
I agree.
Old 06-30-2011, 04:07 PM   #6
Rewards Points: 590
Actually this may work if I decide to stay in the same wall studs. I may move over wall studs though. Thanks for the suggestion!
Old 06-30-2011, 04:10 PM   #7
jbfan's Avatar
Rewards Points: 650
No need to root around in a hot attic when you can drop the wire to the old receptacle.
Old 06-30-2011, 04:36 PM   #8
Rewards Points: 590
Just thought about something.
How can I feed the new wire into the old receptacle's box? Won't that be difficult to feed the new wire into a tab on the old receptacle box?
Whats the technique?
Old 06-30-2011, 04:43 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
I usually knock out the old box, fish in the new wire and install a replacement old work box.
Coastal South Carolina
Old 06-30-2011, 04:45 PM   #10
Drop a piece of string into the hole above the box. Use a piece of wire with a small hook on it thru the knockout to catch the string.
Old 06-30-2011, 09:16 PM   #11
Rewards Points: 590
I had to rip out the old box to be able to fish the wire down to it. Tore a little bit of drywall, but nothing some spackle can't fix.
Had to twist 3 romex runs together + pigtail for the outlet. Tight fit in that old work box, but it made it.
Thanks for the tips.
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 06:07 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Adding an outlet to an existing 3 way switch poghl0069 Electrical 3 09-09-2010 01:21 PM
Adding receptacle on existing circuit schnitz411 Electrical 2 08-12-2009 05:15 PM
