-   -   Adding outlet to existing circuit. Which way? (http://www.diychatroom.com/f18/adding-outlet-existing-circuit-way-109287/)
noone 06-30-2011 02:50 PM
172 Attachment(s)
I want to add an additional electrical outlet to a circuit. Existing Romex on the circuit runs in the attic down the wall.
There are 2 options as I see it, since there is no slack in the existing Romex. Use 2 junction boxes in the attic to splice in to the existing outlet's romex or pigtail off the new outlet and use one junction box.
Thoughts and suggestions?
oh'mike 06-30-2011 03:06 PM
Either one will work just fine----I like #2 better ,but the cable might be stapled and impossible to remove.
Your call---both are safe.
noone 06-30-2011 03:17 PM
172 Attachment(s)
Yeah, option 2 is doable, just harder.
Thanks for the verification.
I just wanted to make sure there wasn't some other way that was slipping past me.
I might get lucky with some slack on the line, who knows.
jbfan 06-30-2011 03:50 PM
Are you installing a receptacle above the exsisting receptacle?
Just cut a hole for the new receptacle, drop a new romex to the exsisting box and make connections there.
Jim Port 06-30-2011 04:05 PM
I agree.
noone 06-30-2011 04:07 PM
172 Attachment(s)
Actually this may work if I decide to stay in the same wall studs. I may move over wall studs though. Thanks for the suggestion!
jbfan 06-30-2011 04:10 PM
No need to root around in a hot attic when you can drop the wire to the old receptacle.
noone 06-30-2011 04:36 PM
172 Attachment(s)
Just thought about something.
How can I feed the new wire into the old receptacle's box? Won't that be difficult to feed the new wire into a tab on the old receptacle box?
Whats the technique?
rjniles 06-30-2011 04:43 PM
I usually knock out the old box, fish in the new wire and install a replacement old work box.
Jim Port 06-30-2011 04:45 PM
Drop a piece of string into the hole above the box. Use a piece of wire with a small hook on it thru the knockout to catch the string.
noone 06-30-2011 09:16 PM
172 Attachment(s)
I had to rip out the old box to be able to fish the wire down to it. Tore a little bit of drywall, but nothing some spackle can't fix.
Had to twist 3 romex runs together + pigtail for the outlet. Tight fit in that old work box, but it made it.
Thanks for the tips.
