Adding An Outlet To An Existing 3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 12:17 PM   #1
Adding an outlet to an existing 3 way switch
I would like to add a recepticle to an existing 3 way light switch. The switch is at the end of the line. I also would like to have the recepticle operate seperately from the switch.
I wired all black wires, all ground wires, all whites together. The black wire coming from the wall is going directly to the common screw on the switch. The red wire from the wall is going directly across the white on the switch.
Any help.
poghl0069 is offline   Reply With Quote
Old 09-09-2010, 12:32 PM   #2
Rewards Points: 79
I am eager to see how this is done. I've never ventured beyond rough wiring and breakers. I will say one thing - make sure its to code - as if there's ever an ensurance claim (heaven forbid) your insurance will screw you.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Old 09-09-2010, 12:42 PM   #3
I expect that you will find that this will not work. Given that your switch box originally has only three wires, it is unlikely that it includes a neutral, or an unswitched hot. Note, the white wire in your diagram is likely NOT a neutral.
oberkc is offline   Reply With Quote
Old 09-09-2010, 01:21 PM   #4
Rewards Points: 410
x2
Did the white have black tape wrapped around it? Power is supplied to the 3-way through the black wire, and then either routes through one or the other remaining wires to the next switch and to the light through that black wire. In your case, since it looks like you have only 3 wires as oberkc pointed out, there is no neutral at the switch.
Light switches is one of those situations white is commonly used as a hot (often it's wrapped in electrical tape or a given if attached to a switch).
Here's a good video that demonstrates how a 3-way works, I find pictures & videos more useful. Although in the video he colored one of the wires blue, in real life 99.9% of the time it would be white instead (like almost certainly your situation). He just didn't want to confuse anyone with the real neutral, but it also demonstrates how and why 3 wires act as hots in 3-way switches.
Piedmont is offline   Reply With Quote
adding outlet from light switch tad Electrical 17 06-05-2009 11:25 PM
Adding a single pole switch to 3 way switch. adrien2 Electrical 6 05-28-2009 02:44 PM
Electrical Question - adding a 3 way switch to existing Light Marcus23 Electrical 5 10-11-2008 08:52 AM
Adding an outlet to a wall switch Keyo77 Electrical 6 01-01-2008 11:22 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
